Inlay Logo with thin or medium superglue?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=56792
Author:  Bill Higgs [ Wed Sep 18, 2024 2:54 pm ]
Post subject:  Inlay Logo with thin or medium superglue?
When inlaying a mother of pearl logo do you use thin or medium superglue?
Author:  SteveSmith [ Wed Sep 18, 2024 3:33 pm ]
Post subject:  Re: Inlay Logo with thin or medium superglue?
I flood with thin then give it a shot of GluBoost.
Author:  Kbore [ Wed Sep 18, 2024 10:19 pm ]
I've used 24 Hour epoxy , thin CA, med CA and Glu-Boost Fill and Finish. I have also spot CA'ed the inlay, let it cure for a couple of hours then follow with epoxy. In all cases, I added black dye and rosewood sanding dust. 24 hr Epoxy seemed to be the easiest to file/ scrape and sand level. When adding dye to epoxy, mix dye into the resin first before mixing in the hardener.
Author:  Pmaj7 [ Thu Sep 19, 2024 7:37 pm ]
Thin if it's a fairly tight fit. Black medium if I'm putting it in black ebony if there are some gaps.
Sent from my SM-A526B using Tapatalk
Author:  Darrel Friesen [ Fri Sep 20, 2024 5:59 pm ]
I most often use G2 epoxy mixed with ebony or rosewood dust. I always seem to have gaps. I make them a hair larger when inlaying into lighter woods so there is an even dark border around my inlays. I might be a little rough, but I'm slow. :)
Author:  Terence Kennedy [ Fri Sep 20, 2024 10:36 pm ]
I fit the inlay, rub appropriate dust into it with my finger and hit it with ultrathin Gluboost and accelerator.
Block sand and repeat if needed for any small gaps.
Author:  Michaeldc [ Sat Sep 21, 2024 8:18 am ]
I’m a CNC guy, so my inlays are a light press fit. Once you test fit them it’s almost impossible to get them back out. Wicking in thin CA is the only choice.
M
